Just found out that rasters (in this case) pdfs) are not showing in Raster Manager with CONNECT. The same file opened in SS£ has the rasters listed. See below.
This is CONNECT
This is SS£
Hi Stuartw,
The Raster Manager dialog in CONNECT Edition shows 2 of 2 listed so I believe something must be wrong on your side . I could not reproduce the issue on my side with the default settings
In the plane column can you verify that the rasters are in background plane?
Open the raster manager dialog and from View Menu make sure you have selected by default
Background, design and foreground. If this does not work Maybe you can send us the file for testing
Maria Garcia
Unknown said: The Raster Manager dialog in CONNECT Edition shows 2 of 2 listed so I believe something must be wrong on your side . I could not reproduce the issue on my side with the default settings
I'm not sure why it would be wrong my end. There must be something wrong with CONNECT as it doesn't show the rasters like SS3 does.
I've gone through the various view options and the rasters are now showing but it took a bit of fiddling. Sometimes they appear some they don't.
Hi stuart,
can you provide more information about the design file and attached rasters?
With regards,
Jan
2 year old thread, but I thought my problem must be common.
Connect Release 8, attached rasters simply disappears, then come back. This applies to both viewing/working on a file and printing said file.
File shows the shape for the rasters, identifies as element type raster, but dialog is empty and raster (PDF) not displayed. Close, re-open, it's fine.
Done it with pdf, sid, ecw, fairly confident it's all raster formats
