All
I have just installed CONNECT on a HP Laptop with a NVIDIA Quadro FV 770M graphics card. The latest drivers are installed but I get the strange zinger lines.
At first I tried the QV_D3DVERSION = 9, but released this has been superseded by; QV_DISABLE_D3D11
NOTE: Using the QV_DISABLE_D3D11 removed the issue.
Question: What are the in-pack of using either or both of the following new variables:
QV_DISABLE_D3D11
QV_DISABLE_HARDWARE
Ian Lapper
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: Ian Lapper
Hi Marco & Tim,
I know that this is an old thread, but the issue continues. Originally I had NVidia video cards, but I continued have driver issues. So I switched to AMD video cards. The worked fine until about the time Mstn CE U11 came out. Since that point, I have had two different (but related) video cards in my computer with at least three different versions of the driver software. And I still have video issues.
Marco Salino said:If you encountered any incompatibility with your graphics card drivers, please contact our Technical Support colleagues
Marco Salino said:those variables are strictly meant for testing purposes only.
The response back that I get from filing a support ticket (after lots of effort) is "Using QV_DISABLE_HARDWARE = 1 will be the fix until the hardware vendor delivers a suitable driver."
My specific condition is Windows 7 Pro 64-Bit, AMD Radeon Pro WX 5100 (previously AMD FirePro W5000) with the 2019.Q2 drivers.
How are we (the customers) supposed to get this situation fixed?
--Thanks,--Robert Arnold
did setting the disable variable solve the problems you are encountering ?
Yes, the visual problems went away...
--Robert
