Is there any tool in Microstation Connect like Atool in Version V8?
Henk Ligtvoet said: You could consider using Text Fields
While Text Fields are one answer to the question, they aren't a particularly good answer. Text Fields lack any kind of reporting facility. It's a reasonable bet that anyone wanting to have areas annotated will also want to extract reports of those areas for use elsewhere. For example, you may want to annotate room areas on a floor plan and subsequently perform calculations on those areas in Excel or some other tool. If you can't extract a report for use in Excel, Text Fields don't even get you half way.
MicroStation CONNECT introduces Item Types, which I believe are a complete answer to the question. Item Types let you attach data to a graphic element, and also have reporting and table options. Data can be exported from Item Types in numerous ways, powered by the underlying EC Schema technology. Please correct me I'm wrong!
Jon Summers said:MicroStation CONNECT introduces Item Types, which I believe are a complete answer to the question. Item Types let you attach data to a graphic element, and also have reporting and table options. Data can be exported from Item Types in numerous ways, powered by the underlying EC Schema technology. Please correct me I'm wrong!
True in theory. In reality my brief attempt to use them has resulted in 6 defects filed and another group still under investigation. At this point I would advise extreme caution and rigorous testing before using them in a production environment.
DavidG said:At this point I would advise extreme caution and rigorous testing before using Item Types in a production environment
Thanks for that comment.
Should we consider porting AreaAnnotator to MicroStation CONNECT?
AreaAnnotator is freeware. It's available for MicroStation V8i. AreaAnnotator automates area annotation by enhancing MicroStation tag elements. MicroStation tags have reporting tools. For MicroStation V8i, AreaAnnotator answers the original question.
Bentley Systems have repeatedly commented on this Forum that tags are obsolete, deprecated, almost gone, nailed to their perch. Given such antagonism to old technology we're reluctant to port AreaAnnotator to CONNECT. Perhaps we should reconsider?
