Microstation V8i series3-v 08.11.09.459 and BU-353-S4 USB GPS Receiver
I have been able to get Bentley Map to track my movements, but have been unable to get Microstation to do likewise though the same tools are available.  In BM, as long as the session is active, I can see the tracks, but am unable to manipulate.  I am assuming that I will have similar results if and when I can get Microstation to track.the same way the BM.
My goal is to merge field work with traditional drafting to net a more accurate finished product.  Can any of you point me in the right direction?
  • I am using V8i, select series 3 - v 08.11.09.459. and have also attempted to use with MicroStation Telco V8i - v 08.11.09.524 with the same results. When I try to activate the antenna, the button will not do anything. I downloaded Bentley Map V8i, select series 4, v 08.11.09.615 and it activates fine. I just can not manipulate the track that is generated. Any help is greatly appreciated!
Reply
