We have upgrade to Microstation V8I (Select Series 3) – Version 08.11.09.459 and it appears the customise tab under the workspace pull down menu has been removed from the task bar. I copied the dgnlib file from our previous version and have pointed the pcf file to the dgnlib and the pull down menu attaches and works.
My question is how can I edit or add a pull down menu to the task bar and where is the customise functionality moved to..
Any help is appreciated.
Joe
Are you sure that you have installed the full MicroStation V8i SS3 and not the PowerDraft version. As this is a cut down version it would not have the Customize option in the Workspace menu. If you use the following keyin it will open the Customize dialog it you just have PowerDraft. CUSTOMIZE DIALOG Otherwise it may be as Leonard has suggested and this option has been removed from previous customizations in the DGNLIB.
