How to change display style to wireframe for acute3d mesh? It doesn't seem to honor active display style.
Keith Raymond
Exporting to GE may not be correct because the SRS systems in different Bentley programs and versions are messed up for us. EPSG3059 system is only fixed in CONNECT edition so the XY are not interchanged . Contextcapture may have the same wrong SRS system set in 3mx files. Regarding Global Origin in help it states that it is aligned but it is not needed to change it in active file nor it is expected.
I see that if 3mx file is opened directly then coordinates are correct but GO is shifted that explains why DGN doesn't correctly export to GE because it was drawn on top of 3mx file and now if attaching 3mx mesh it shifts the GO again.
