[CONNECT] Reference presentation setting ignored.
it seems if a reference file has defined own presentation (display style), it's ignored in MicroStation CONNECT Edition.
I created simple test case, where a slab is in active model (work3d.dgn) and it's shaded and a sphere is referenced from another file (work3d B.dgn) and the reference is attached with wireframe display style set.
This is how it's displayed in V8i (SELECTseries 3) Update 2...
... and the same files in CONNECT Edition.
Or it's because some default setting has changed in CONNECT Edition?
The used files are attached.
With regards,
  Jan
bug-reference-presentation.zip
