if there is an element with a tag attached, an information about the tag is not displayed in Properties dialog (former Element Information dialog).
As an example, here is the dialolog with a selected line element with tag:
With regards,
Jan
Hi Melissa,
Unknown said:and you have the option in the item types dialog to upgrade your tags to item types.
Such advice is highly theoretical. I am a big fan of Item Types as I like EC technology for many years, but your recommendation is pretty far from reality that is not about "lets start to use Item Types".
I have had many discussion with my customers about CONNECT Edition and how to migrate and a simplified summary, using some assumptions about future release, of these discussion is:
... so tags will be there for many years and if anything doesn't work as in V8i, the answer cannot be "use Item Types".
Unknown said: If you turn the display of the tag on. then it will appear in the properties dialog.
Good finding! You are right, displayed properties depend on the tag display setting, I confirm if the switch is set on, it works fine.
For sure, it's bug.
