Ok so am relatively new to microstation and I'm trying to figure out how to create a new project configuration file. I have tried searching for any kind of documentation that explains how they are created / how to create one and come up short. Any help would be greatly appreciated, thanks.
Please tell us which version of MicroStation you are using: MicroStation V8i or MicroStation CONNECT. Answers will differ depending on the version!
Unknown said:I'm trying to figure out how to create a new project configuration file
Creating a configuration file is easy, because they are plain text. Use your favourite text editor (but not a Word processor that doesn't write plain text). The tricky part is knowing what to put in them.
MicroStation help is useful: start with the section Setting Up Projects, which contains chapters about configuration variables and files.
Timothy Hickman
Main: 877 627 3772|
