Ok so am relatively new to microstation and I'm trying to figure out how to create a new project configuration file. I have tried searching for any kind of documentation that explains how they are created / how to create one and come up short. Any help would be greatly appreciated, thanks.
When you open MicroStation V8i the first dialog you will encounter is the File Open dialog or what we might have previously called MicroStation Manager. In the bottom right corner of this dialog you will see the User, Project & Interface items which once created will assign default UCF, PCF and interface files that you would be able to customize.
You might find the information in the Help Documentation of MicroStation V8i useful in understanding what you are required to do for the workspaces.
> Help > Contents > Setting Up Projects > Workspaces > Workspace Fundamentals
The following Wiki articles provided by "AskInga" might also be of interest.
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/learning-about-workspaces
MicroStation V8i SS10 Ver. 08.11.09.912
PowerInroads V8i SS10 Ver. 08.11.09.918
OpenRoads Designer CE V 10.04.00.48 Release 2
Civil 3D 2018 Ver. 12.0.1386.0
