I'm working with Microstation V8i SS2. My Problem:- I want to import Coordinates from an ASCII-File into an DGN
- The ASCII-Files contains the following Information
X, Y, Z, Number, point-type, Description
The point-type is a number between 1 and 999
- I want to visualize the following information:- Symbol for the point (cell)- point - Number- point - Elevation- point - Description
The thing is, that i want to write this information into a DGN into different levels, depending on the point-type, that is e.g. for point-type 120 I want to have the following levels:
120_point120_number120_elevation120_description
I want to be able to do the import in one step, and not several!I know the xyz-import-function, and i also know the mdl PLTPNT.MA. That's just not quite what im looking for.
Does anyone know a solution to this? Thanks in advance
Guido Weber said:I want to import Coordinates from an ASCII-File
Can you provide a sample file?
Guido Weber said:I want to have the following levels
Do those levels already exist?
Guido Weber said:Symbol for the point
