How do I set the default reference attachment of Drawing Boundary to None? I've looked in Preferences and the option under the configs but can't locate this.
Hi Stuartw,
No sure if you are asking about the option to set Drawing boundary to none in the case of attaching a reference to a sheet model. If that is the case you can just select none from the Reference attachment dialog.
See image
if this is not what you are looking for please send a screen shot or elaborate a little more.
Maria
stuartw said: At the moment it always reverts to 'new', which is a pain
Agreed. Never notice it on placement. Then I go to cleaning up a file and find these annoying callouts in the middle of nowhere.
From what I can locate for the Configuration Variables there does not seem to be any setting that specifies what this can be defined as by default. I would have thought it might have been defined within MS_REF_DEFAULTSETTINGS. I do see that there is a key-in that you might find useful. REFERENCE SET DRAWINGBOUNDARY (none)
