How do I set the default reference attachment of Drawing Boundary to None? I've looked in Preferences and the option under the configs but can't locate this.
Unknown said: From what I can locate for the Configuration Variables there does not seem to be any setting that specifies what this can be defined as by default. I would have thought it might have been defined within MS_REF_DEFAULTSETTINGS.
This config doesn't have the option to change Drawing Boundary to None, but is should have to be consistent. Can this be included in the next update?
Unknown said: I do see that there is a key-in that you might find useful. REFERENCE SET DRAWINGBOUNDARY (none)
When do I use this keyin
