Delimited Text Files to dgn text coming into dgn out of line
.LS=.4
.TH=:1.80
.TW=:1.50
.LL=250
.FT=4
BTNMDIX-V630-CA11-BA006 0092-006 F0002  PHOSGENE GENERATOR #3
BTNMDIX-V630-CA11-BA007 0092-007 F0002 GENERATOR COOLING LOOP SEPARATOR #1
BTNMDIX-V630-CA11-BA008 0092-008 F0002 GENERATOR COOLING LOOP SEPARATOR #2
BTNMDIX-V630-CA11-BA009 0092-009 F0002 GENERATOR COOLING LOOP SEPARATOR #3
BTNMDIX-V630-CA11-WA010 0092-010 F0002 GENERATOR COOLING LOOP CONDENSER #1
BTNMDIX-V630-CA11-WA011 0092-011 F0002 GENERATOR COOLING LOOP CONDENSER #2
BTNMDIX-V630-CA11-WA012 0092-012 F0002 GENERATOR COOLING LOOP CONDENSER #3
BTNMDIX-V630-CA11-AM013 0092-013 F0002 GENERATOR COOLING LOOP EDUCTOR
BTNMDIX-V630-CA11-WA016 0092-016R F0003 FRESH PHOSGENE CONDENSER
BTNMDIX-V630-CA11-RM017 0092-017 F0003 POST CO/CL2 MIXER
BTNMDIX-V630-CA11-CA018 0092-018 F0003 POST PHOSGENE GENERATOR
for some reason the text is not coming into the dgn space delimited as shown...text comes in out of line...what to do?
  • Additionally there may be TABs in you data. Can you provide a sample file?
  • Monique,
    Does it have to be Microstation Text?
    If while in Excel you select all your cells you can control C copy , then in microstation you can  paste special and choose excel ( I prefer embedded as it becomes part of the cad file) there are several choices but dont use the  image choices...
    you can then place by dynamic points or size etc .. if you make the excel file  xls instead of csv  you can use some   cool formatting headings, bold, borders around each cell etc and these then are preserved in cad... only issue is if you are forced to use a font..
    If you must use a msnt  font then there is a little known macro delivered with microstation that will draw a table with lines and use active font etc.. it takes a few practice go's if you never used it  before  but its pretty great and leaves you original text file intact it just imports it ... search your system for table.bas or try running it from command line with  keyin
    macro table
    After you run it it asks for your txt file ( you can aslo select csv from pull down)
    then data point and your table starts drawing and populating via the settings used.. pretty cool really...
    you'll also find a text file called table in the same folder as an example of the  formating FYI  it doesnt like over rides on   so turn that off from  Control B.. otherwise it works fine.. you may have to tweak the  results with  fence stretch and  clip or scale  etc  but I've been using that  on and off since 2002 when I'm not allowed to use windows fonts or excel copy paste...
    here is screen shot ...I used the engineering msnt  font  if you cant find the macro or dont have it  email me  or Private message me and I'll send it to you...
    it has  preferences that you need to set  ie colours lines on off  column widths in master units not characters
    The first line is the headings, number of columns depend on how you have the column delims set in your text file .. this macro  I find works better than plain import text  from a file....
    Also if you dont want the  line work you can just delete it or turn off  the  options for separators  in the settings and have only  the text , but I prefer to group the text as a selection so it  moves together as one object for ease of location in best spot...
    Give it a try  you'll love it!
    Lorys
    click link to PM me
  • Hi Monique!
    Copy the text (Ctrl C) and Paste (Ctrl V) the Text into the MicroStation "Text Editor - Word Processor" dialog.
    Assuming you have the correct Text Settings Font, Size, Spacing, etc. settings you can now Set/Adjust the Tab spacing (See attached image.)
    I hope I have the right Idea as to what you are having trouble with.
    I Hope This Helps Someone Reading This!  (Intergraph>PseudoStation>MicroStation user since 1980's)
    Answer Verified By: Monique Burns
  • From what I can see. The space before "_"POSGENE was in the original text I copied from your post. You were using Tabs to Deliminate between columns. The resource Font I used, is not mono-spaced.
