for some reason the text is not coming into the dgn space delimited as shown...text comes in out of line...what to do?
That spacing is set by the Line Spacing setting for Text Placement. The Line Spacing is a portion of the Text Size (i.e. a Line Spacing of 0.5 would equal one/half the size of the Text.) If the text Size is 4 and the LS=.5 the Spacing between each line of text would be 2.
This means From the Top if the First line to the top of the second line would be 6. This can also be affected by the Line Spacing Type setting in the Text Style. I usually have it set to "At Least"
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
