When I double clicking on microstation file from windows explorer I get an error message:"access Violation occured at 0x006c6c28...". But same file, same location, the other friends can double click to open it. I think my computer need some set ups. Does any body please help me know how to set it up?
Please identify the version of MicroStation you are using: MicroStation CONNECT (64-bit) or MicroStation V8i (32-bit). What is the 8-digit version number (e.g. 10.xx.yy.zz) of MicroStation?
What version of Windows are you using?
BHD @ Jacobs
Answer Verified By: Bichhanh Dao
You're using MicroStation/J on Windows 7. That version of MicroStation is not certified for use with Windows 7.
You've marked your post as answered, but I don't see any answer here! Have you solved your problem?
