CONNECT - Deleting Variables and re-mapping doesn't always work
The ability to delete a variable and remap it to a new variable is awesome, but a tad un-predictable.  In the attached file, if you open the "test" model and delete the variable FplusG remapping it to G then equations which used the variable FplusG get very broken.  For example if you look at RodLength before and after you'll see the equation changes from STROKE + STOP_TUBE + FplusG + V to G + G + G + G.  It also effects StopLength changing STOP_TUBE + FplusG + V to G + G + G.
I would expect these two equations to become, STROKE + STOP_TUBE + G + V and STOP_TUBE + G + V respectively.
2A-TB.dgn
