Snapping on the specifing level
Hello!
I would like to know is there any possibility to snap on the specific level in Microstation v8i? You can see the example on the picture below.
This is my starting situation:
I would like to expand the blue area under the red area (which on the top view is outside of the blue area). Thats why I use the top view and snapping. Unfortunately, this is the effect:
As you can see, the points are not on the same level. Could you help me with putting the points on the one height? Only manually editing in the object settings?
