I am using Microstation v8i SS2.
I need to draft a custom hatch pattern and not seeing much about that. I thought I could just draw linework that represented a hatch pattern and use as a cell. But apparently there is more to it than that. Are there white papers on the subject of creating custom hatch patterns?
So you have two cells, one that will flood a boundary and one that will not?
Does this happen when you use the same boundary?
You can open cell libraries just like you open a design file. Each Cell is a Model. From there you can analyse - Element Information, model properties, etc, s to try and figure what is different in each one.
