I have s sheet model with a floor plan referenced in. This floor plan has areas identified with additional information on other sheet models. These areas have links attached which take you to the other sheet models. Two out of the three links that I have made (note that these were originally done in SS3) work OK but one doesn't, and has a different icon. This icon is different in SS3. The pop up for the link shows the correct sheet model, but the follow link fails. any ideas?
I responded to you on your SR via email with a way to fix the link. I still don't know what is actually causing the issue, but I'm guessing there's some corruption somewhere.
Cheers,
Erik M.
