When I attempt to use No Workspace (Client) -> No Workset Browse uses the previous Workspace name to look for a folder No Workset\DGN.
This results in an error and does not allow browsing for files using No Workspace -> No Workset
Ian, Thanks for the conformation. I ran into this during the EAP and thought they would have it sorted by now. Yes I find it bizarre you have to create a Workset in order to not use a workset. This also brings up the issue that we can't browse a workspace without specifying a workset.
To overcome the issue of not being able to Browse with a 'No Workset' defined. I have had to add a folder to the path as displayed by the Alert. i.e. I needed to add the Workset\No Workset\DGN folder to the system
Although this works, I do not want to use this as a permanent option. It makes a clean setup look messy. What have others done to get around this issue?
Ian
