In the Place text tool, we have the option to place a Text Field as per SS3. In the area Formatting section, there is an option for the Unit Decorator. This has two options;
'Sq.Unit' or 'Unit 2'. These are defaulted to sq.m or m2
Where can i define the unit for Unit2. I want it to be m²
Ian
Just for the benefit of others Ian is referring to
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/make-your-field-units-display-with-superscript-text
Carl Myhill
Technical Support Engineer
Bentley Systems
