How do i copy to the clipboard with the new CONNECT View? This seems to have been removed from this new version. In the old version you could use Edit> Copy or right mouse click and Copy to Clipboard. Both of these are no longer available. Why? Ctrl + C also doesn't work by the way.
Unknown said: I can confirm that Ctrl+C does still work in a default installation of Bentley View
Define default installation. When I installed View it found automatically the srevre workspace that we use for CONNECT MicroStation.
Unknown said: All of the Copy&Paste options are still available under the right-click menu within MicroStation so I would suggest if this is your preferred workflow that, as DavidG has suggested, instead of installing another piece of software you should just open another session of MicroStation on the second monitor.
That's a brilliant idea. I'll open CONNECT MIcroStation on the right as a viewer (about all it's useful for!) and SS3 on the left as main main drawing program. Thanks fro the heads up.
