I am modeling a pump. Now, there are several variations that different models of this pump may have (different diameters, different heights, etc). I want to create parametric cells that contain those variations. I would like to link the parametric cell to a table (on Excel for example) containing all the info, because it would be way too much work to do it one by one introducing variations by hand.
I could not find any info on this on the web.
Thank you,
Andrés
sorry for the delay.
If you want to export in a *.csv file the variations of your parametric cell, you can use the Export tool, under this path:
Drawing>Constrains>Dimensional>Variables>File>Export.
Maybe this screenshot can help:
regards
Mara
Answer Verified By: Andres Bellei
Hi, you can see it in this wiki article: communities.bentley.com/.../26616.how-to-export-the-variations-of-parametric-cells-into-a-csv-file regards Mara
