MICROSTATION PASTE COMES IN AT DEFUALT 45° DEFAULT ANGLE
This is super annoying and was wondering how (if any) I could change the setting to 0° instead of having to change it every time. I have also tried saving 'Ctrl F' and 'Ctrl S' but it still reappears when I reopen a drawing.
Any advice much appreciated
Thanks in advance
Jamie
check your seed file it may have the aa=45 and the model space may be rotated..set it to vi=top
what about this
create a batch process script like this
it will fit the view set the active angle to 0 and rotate view to unrotated and saves the settings and saves file this way
Then you choose the files to process so fix all existing files ( do this first in a test limited run batch, then in small group files batches to be safe with nobody using them)
fit view extended all
AA=0
vi=top
file design
or string these together in a F key joined with semi colons ; and process a file when you need it...
Lorys
