Error Opening File
I am having issues with Microstation failing to open a DGN file. It comes up with the 'Error opening file [FILEPATH.dgn] = (0x13013)'. It crashed when I was trying to open one of sheets that I have created. The following log is taken from the Event Viewer when Microstation crashed. Please advise on how to recover these files. I have attempted to open previous versions of this file through Windows explorer but the same error came up. So now it seems like I have to start my work all over again. Urgently needs advise. Thanks.
Faulting application name: ustation.exe, version: 8.11.7.443, time stamp: 0x4c3f498c
Faulting module name: ustation.dll, version: 8.11.7.443, time stamp: 0x4c3f31e5
Exception code: 0xc0000005
Fault offset: 0x003a8098
Faulting process id: 0x1dd8
Faulting application start time: 0x01d1517aed2e491f
Faulting application path: C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\ustation.exe
Faulting module path: C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\ustation.dll
Report Id: 91e0ee42-c2ec-11e5-9e6c-3417eb9697fd
Parents Reply
  • Hi Ryn :
    Please request your IT/Network Administrator to have a look at the event logs. There are machine specific warnings and errors. One of the warnings is specific to the corrupted DGN file.
    {Delayed Write Failed} Windows was unable to save all the data for the file \Groups\SS-Vic\@GMT-2016.01.19-20.00.17\UNITE .. ngs\J1-UGL Drawings\DP102 - BP\RWY_G0015_1.dgn. The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere.
    Leonard Jones
