How do I constrain a parametric cell to the endpoint of a line?
The black rectangle is a parametric cell with the origin at the center. I want to constrain it to the end point of the vertical green line which is part of a constrained model.
This is a 2D file.
have a look at this screenshot:
AD is parallel to red line, AB is perpendicular to red line and I have constrained the two distances
regards
Mara
I have used "construction lines", the diagonal in blue, you can hidden them using the Level Manager.
Divided the diagonal in 4: AO, OC, DO, OB.
I have used coincident constrains:
point between OB and BC
point between OC and BC
point between all the 4 semi-diagonals and red line
look into the screenshot and file attached:
constraints cell.dgn
