Is there a Named Expression to check for a specific sheet name?
I am looking for info for a Named Expression that determines if a certain Sheet model exists. For example, "BorderSheet"
Or if this isn't possible how about a Named Expression to determine if a specific TagSet exists in the file?
Regan
Parents Reply
  • Hi,
    Unknown said:
    Would it be possible to get the source code as well?
    No. I released this SymbolProvider several years ago as freeware, so right now it's closed solution. I thought already to put it as open source to e.g. GitHub, but because of total lack of time it will not happen soon. The development is based on playing with a code without detail documentation, so before such migration will happen, I want to be sure the code is correct ... and personally I have also to be clear I really want to open and share my not small invested effort and time ;-)
    Unknown said:
    Also, is there a good resource that teaches how to build your own named expressions?
    As far as I know there is no documentation and SymbolProvider API is not a part of standard MicroStation API, there are only functions to work with existing providers and expressions. I did my testing and research based on notes from BDN conference several years ago (I guess it was 2008), I don't know about any other. So if you are BDN member, you should have access to the materials.
    I have no problem to add or modify the functionality if there will be valuable request and enough time to implement it, as I already did with some my other free tools in the past.
    With regards,
     Jan
