OK, so half the parametric doors in my drawing just disappears... again. Will I never learn? Never believe what a developer says in the Marketing BS.
I've used every Major rev of MicroStation ever released and have Beta tested starting with V4. This has too be the most unstable product (10X) that I've had the extreme miss fortune of using. Who ever is responsible for releasing this as a usable product should be fired. They either have no pride on no clue about quality. Its truly sad to see a company that once led in performance, stability and features decline to such a level.
Sincerely
DavidG
although I think there are many things Bentley can and shoud do better, I disagree with you in some topics:
Unknown said:It looks like Bentley doesn't really test its product before releasing it.
It made me laugh. Seriously, testing of any software product today is nearly never realized as ticking checkbox or whatevever else on GUI level. I am very sure Bentley developers implemented complex both code and user testing. Despite of plenty of bugs and "not bugs but not good enoug implemented features" have been discussed, MicroStation CONNECT Edition is pretty stable from its first beta.
As far as I know nobody in software industry today believe or expect it's possible to produce software without bugs, especially if it's complex as MicroStation and if rewritten from scratch. Yes, testing (and there are many types of testing used in software development) decreases number of bugs, but it doesn't solve everything. So important is (and it's one of a main idea behing agile development) how quickly are you able to implement the fixt and to release a new version. And it's what Bentley don't do well in my opininon: Waiting many months for new version if everybody had to know years ago that at least one year after CONNECT Edition well be released many bugs and backlogs will be discovered is bad.
Unknown said:So, you do not test a product by ticking boxes whether you can open a file, draw a line, open reference dialog box, copy/paste etc. to mention a few.
Hmmm .... so why all operations you mentioned work fine? My feeling is the most of discovered bugs are associated with a different functionality between V8i and CE, often in complex scenarios (probably because the code was rewritten) or with new features like parametric modelling (which is completely new concept in MicroStation developed on new Parasolid library). I see no option how open a file, draw a line, open reference... can discover these bugs.
Unknown said:It took Bentley 14 years to create a 64-bit application
Interesting. Woudl you be so kind and to explain how do you compute 14 years? Or is it just "a number" to express how bad Bentley are?
Unknown said:Using the CONNECT Edition as platform for other products is going to be a nightmare!
Do you have a personal experience? As far as I know no product like PowerCivil, Bentley Map or AECOsim Building Designer has been released yet on CONNECT Edition platform? I guess the main reason of this fact (which is not good at all, because these products are often more imporant than MicroStation itself) is not (in)stability of MicroStation, but an effort required to migrate and rewrite applications code, adapt to a new GUI, new configuration structure etc. i hope Bentley will be able to release them this year.
With regards,
Jan
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
