CE - Quick Access bar Edit
HiAll
I have imported my V8i Pull Down menus into the CE Quick Access toolbar.  Although I am not impressed with their location, they do work.  However, I now need to edit some.
Within the Customize Ribbon dialog, I can see the QA tools, I can drill down to my sub level commands etc..  in V8i these menu items had a series of commands that i join together via the keyins and loaded up vba commands etc.  In V8i I could edit these very easy.
however, once they are imported into CE, There seems to be no way to edit them..
Anyone done this
Ian Lapper
  • Hi Ian,
    to me the ribbon customize dialog still seems to be a little buggy.
    So I started to:
    • export XML files (only once)
    • edit them in Visual Studio (or some other text editor of your choice that can handle XML files)
    • revert ribbon customization
    • import edited XML file
    It may not be very convenient but gives maximum control.
    The keyins are:
    1. ribbon customizations exportecxml
    2. ribbon customizations revertall
    3. ribbon customizations importecxml
    If you open XML file first time in text Editor there are two steps to do:
    1. replace all "...><..." with "...>[newline]<..."
    2. autoindent document (works in Visual Studio, dont knpow about other Texteditors)
    @Bentley: I wonder why the exported XML files come in such "unformated" way?
  • XML Pretty Print
    XML data is intended for machine consumption rather than human consumption.  The formatting (or lack of [newline]) is neither here nor there.
    However, I agree that it's hard to read (as a person) XML data: the process you've gone through is termed pretty printing.  If you get an XML editor, then most usually have a pretty print tool.  First, talk to your IT people to see if they have a favourite XML editor: it may be available throughout your organisation.  If that's not the case, then consider these...
    Regards, Jon Summers
    LA Solutions
    Per W3C XML Spec 1.0
    1.1 Origin and Goals
    #6   XML documents should be human-legible and reasonably clear.
Reply Children
