In V8i Element Information, double-clicking the value of Line Style / Weight, it will give a full selection of the text for me to re-type the value.
In Microstation CE, I guess to say someone requested to increase the number of value after double-click. However, the ability of full text-selection is gone. I think that developer can solve this by +1, and then select the text. Moreover, developer shall add a key-press event for decreasing the value. e.g. Shift + double click.
Your screen shot doesn't appear to be from CE. I have no problem selecting the field and changing using click and drag in the CE properties dialog.
The change is deeper than it looks: communities.bentley.com/.../113093
Please don't get me wrong, I like the new way changing these options from properties. The problem is the old problem, consistency.
As per Andrew advice I would advise you to raise a Service request.
José
But both "Click + Drag" and "Right Click" are lower than a double click to select and change the weight from 1 to ??. Andrew, any possibility to help raise a enhancement request to balance the user's need? Just add a selection feature for double click, this would not affect the existing users who love the increase in value by using double click.
Which means: after increasing the value, the value keep highlighted.
