CE - Properties General - Priority
There is a defect on Priority. When the element's priority is not defined, it would be in zero. However, when you click for more options, Microstation CE will select -500 first. If you have already defined the element's priority value as zero, it is fine.
Please help file this defect if it is not reported.
