Hi. Are there any tool inside Microstation CE that can automaticly creat centerlines for existing cylinders and bends? Idealy for large selection sets, and for different types of cylinders/bends object types.
Helge
Unknown said:...always get these cad models coming from different cad softwares...
Can you provide a couple of small DGN files, from different sources, that illustrate the sort of pipe runs you want to analyse?
Unknown said: helgeh ...always get these cad models coming from different cad softwares... Can you provide a couple of small DGN files, from different sources, that illustrate the sort of pipe runs you want to analyse?
Unknown said:The most problematic ones are those who translates in to mesh objects...
You've just raised the complexity of the task by an order of magnitude!
Unknown said: helgeh The most problematic ones are those who translates in to mesh objects... You've just raised the complexity of the task by an order of magnitude!
