When I insert a row in my table for example row 10, at row 24 my data disappear. Clearly not the way it supposed to work.
I have not been able to reproduce this ( Sample file attached ).
May be there is some additional formatting in your table that's related to the problem your seeing, we are not able to see the rest of the Table.
How was the Table created in the first instance ? Was it from Place Table, Via Report .......
Are you able to reproduce the problem with this file ? If so please elaborate on how your inserting the row ( Right click Insert Above, using tool in ribbon ..... )table.dgn
Answer Verified By: Ruchika Arzare
