Hi folks,I have text elements (texts and datafields) disappearing from a certain cell when I zoom in on it. This error showed up in someone's drawing yesterday. Turn's out it is messed up in the cell-library. If I open the model I have to zoom way out just to see the text elements. Only one is visible at all times. I can not select them by clicking at random. I have to zoom out, aim-click, then zoom back in to see them disappeare agan. The text is still selected but edit handles are in the wrong location and jumbled. I can select all texts by SELECT ALL and then deselecting all non-text items. Inquiring info is possible, but has no purpose. I've changed all element colours to see if that did anything, but besides being annoying that did nothing.I ran both Fixrange and Verify to no avail. Verify reported a truckload of 'element out of range' things. I restarted Microstation and did a Verify attempt again.It reported once: 'verifyDimStyleEntryElm error: missing attribute data' It reported eight times: 'verifyText_node_2d error: text node component 4428 range is outside range block' with eight component numbers.I turned off anti-alias in the preferences.V8i-SS3 08.11.09.459Win7 (64bit)
Zoomed in
Zoom out
Zoomed out even more
IngB-stempel.cel
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
When I panned so that the text was only partially out of view it dissappeared entirely.
I ran fixrange and verifydgn and now it looks completely normal in V8i.
Can't upload it for some reason. Not sure if this will work...
5732.IngB-stempel.cel
are your active files 3d models?
is the display depth range and active depth compatible ..?
check your prefs file turn off antialias for all both settings, a lot of video cards cant handle this properly .. I havent had one yet that that this setting doesnt ruin the text viewing .. I have had the same problem zoom in and out text vanishes..
Try changes to the prefs restart mstn and see if resolved if not put the setting back , scratch head harder and try video card driver update, or downgrade to earlier.. its a bit of trial and error with video problems... sorry
Lorys
