Unknown said:Would maybe the installation of a SSD hard drive be recommended?
Using an SSD as the Windows system disk makes a big difference to start-up and some apps. Go for 240GByte.
For a quick list of suggested hardware you can see the following:
http://communities.bentley.com/products/microstation/w/microstation__wiki/4175.microstation-v8i-system-requirements-and-hardware-recommendations-tn
As far as the displays go resolution of the monitor can have an impact. If you go to a very high resolution monitor there is an issue with icons and certain gui elements being small for V8i.
http://communities.bentley.com/products/microstation/f/273/t/97324
http://communities.bentley.com/products/microstation/f/273/p/111346/339569#339569
Unknown said: - What screen size, by using 4 displays and 90cm working distance, would be good / the best ? 24 ", 25", 27 "...? - What format should be the best for CAD, 16:9 or 16:10, or depending on the display size ...? - What is the best resolution, what is advantageous and what an absolute no-go?
1. This is really dependent on what works for you. Some people like bigger screens
2. Again this is up to your preferences.
3. Very high resolution screens, such as 4K may be an issue if the monitor is on the smaller side, less than 24".
