I have always used microstation V8 but recently have been introduced to Powerdraft. The userface is a little different so im wondering if survey data can be imported and used in 3d? Any advice or direction will be greatly appreciated.
Hi Justin, Depending in what format is your survey data presented (for example . txt file)
you could also use the xyz Text tool to Import Coordinates. this tool is available from tools menu\Tool boxes\xyz Text
Review this link ( have a look just at the first part how to import xyz) communities.bentley.com/.../26009.how-to-import-coordinates-xyz-and-their-respective-labels-or-text Regards Maria
Answer Verified By: Justin Rush
