V8i select series 3, Add a terminator cell to the end of a line or curve automatically
I am transplant from the auto cad world and I am looking for ways in micro station to do the things that i was able to do in autocad. Is that any way to associate an arrow head automatically to the end of a line of curve without have to use the place cell terminator function, also along that same line is there a way to automatically place leaders with arrow heads at either end of a line or curve with the bearing and distance, or curve information.
Thank you
  • In addition to what Lorys offered:
    You could create a custom linestyle with an arrow at the end. Then any arc or line you draw using that linestyle begins with the arrow. The Arizona DOT has such linestyles in their libraries and Google should find their CAD standards easily.
    You can use the Label Line command to dimension a line to get the angle (bearing) and/or distance.
    Alternately, you could use the Place Note command Lorys referred to and use a field linked to the element to display properties.
    I wrote a VBA to label an arc, and I believe that is what Lorys is referring to. Holler if you need that.
Reply
