Is this new behavior?
Trying to fillet two lines with no trimming. Lines do not physically intersect, but would if extended. The Fillet command responds with illegal definition unless I allow it to extend the line as part of a Truncate function. I do not think that this was normal functionality in earlier versions. And by earlier versions, my memory goes way back...
Answer Verified By: caddcop
Carl Myhill said:I also tried this with MS J and it was not possible, there is an outstanding defect 8166 to address this issue
What's the record for an unfixed defect?
