I apologize if this sounds dumb but.....
Is it possible to remove the option "CAD Files (*.dgn, *.dwg, *.dxf)" from the List Files of Type?
With the file system that is used in this office, they put all of the files (in this option) in the work folder. I generally will only work in .dgn but when I want open another file in the work directory I have to select the "MicroStation DGN files (*.dgn) option. It sounds a little picky but doing this EVERY time I want to open a dgn file it gets to be REALLY annoying since all I want to do is open a dgn.
If it's not possible to remove the option, is it possible to move it to the bottom of the list?
Thank you
Cheers,
Erik M.
Erik Mendoza thank you for the article!
It does what I wanted but the result is that the "List Files of Type" is blank. For me it's fine since I'm getting just dgn files in the list when I go to open a file. Is this the result that is expected when I edit MS_OPENDESIGNFILEFILTER?
Thanks again!
