I can not modify the coordinate of axis Z, just can change the XY plane, when I cut the 3D model with clip volume. any idea?
Thank your help. but there is not 3d clipping cube to be shown after following your suggested steps. any other solutions, please? what's the" apply fitted view volume"? could you show a sketch to clear. look forward to receive your reply.Thank you very much.
I made a self explanatory video for you.
I found that Display Style does not work with 3d clip. I was not aware of this bug.
