how can I activate the button for hide/display the level in the drop-down menu?
Microstation V8 example:
Microstation Connect example:
Connect- Just buy a 3rd monitor. I put a suggestion in Ideas to combine the Level Manager and the Level Display dialogues. Believe it has negative votes.
Best I've found is to open them both up, then dock them on an edge.
Enhancement Request 914978 has been filed with Product Management/Development for review.
If others would also like to see this change or receive updates on this Enhancement please file a Service Request and reference this thread.
Thanks for reporting.
Carl Myhill
Technical Support Engineer
Bentley Systems
Koert said:I think that was removed intentionally because it was a bit unclear what it actually did (Global Display or View Display depending on what you had last used in the Level Display dialog).
Agreed,
mago mago said:how can I activate the button for hide/display the level in the drop-down menu?
There isn't a way to bring this back that I am aware.
I know it doesn't answer your question but why not use the right click option to turn the level off in the view?
~HTH
John.
yep
was this mostly used to turn off levels ?
Timothy Hickman
Main: 877 627 3772|
Yes, primarity to turn ON and OFF level display in my original request.
