If we place a dimension that using a dimension that has the text style predefined and is annotative, everything looks good when the dimension is placed. If we have to edit the text of the dimension, we will use the text edit tool and select the text, after we edit the text we click to accept it. After we accept the change, the text edit is done, but it has removed the Annotation Scale from the text and it shows up super tiny. The rest of the dimension looks good, it is just the text that is small. This didn't happen pre-Connect and I am trying to figure out if there is a setting or some other way to have it retain the annotation scale it had originally.
Thoughts?
Kirk
I Wish Cadland was Reality
Answer Verified By: Ken Harrison
Timothy Hickman
Main: 877 627 3772|
