Match Pattern Attributes Changes Annotation Scale
Again, we are just getting into Microstation CE and trying to see what works and doesn't before we roll it out company wide. We opened a file that was started in MS SS3 that had a hatch pattern that we wanted to match and then create a new one. The hatch that we want to match is in the same model as the text and dimensions, all of which use Annotative Scaling. As soon as we start the Match Pattern Attributes and the select the pattern we want to match, the design model will switch from the Annotative Scale that was set (1/4" = 1'-0") to Full Size 1:1. The text and dimensions still look fine and I can switch the scaling back to where it was, but I'm not sure what this is doing to the file and why it is doing it in the first place. The only tool that does this (that we have noticed so far) is the match pattern attributes tool.
Any idea why this is happening?
Ken
