Attached a PDF and TIFF files as reference (with save relative path checked on), clipped reference to display desired area, save settings and exit. Open the file again but references no longer display. in the view window. What makes the references not to display. Did it several times but got the same results.
thanks,
Cezar
TIFF is a raster format file, and for reference purposes MicroStation treats PDF also as a raster format.
How did you attach your files?
