In the past I have created custom icons and have migrated them to the latest version of microstation ss3. Now I'd like to create new icons but I can't seem to figure out how to do it.
Does anybody do this anymore? Can you give me a place to get more information?
Thank you
I'm facing a similar question: how should i create icons and how assing these to buttons in Microstation Connect Edition? I know how to customize the ribbon, but I was never able to assign icons to new buttons other than the ones in the rsc list. Might this relate to a configuration variable too? Thanks in advance.
Hi Pau Arbues,
Pau Arbues said:I'm facing a similar question
It's always best to start a new threath as described in best practices.
Pau Arbues said:how should i create icons and how assing these to buttons in Microstation Connect Edition?
Even more with a different version of the program.
You'll have to open your DGNLib file to be able to make customizations on your ribbon. Inside Customize Ribbon you can use the button ... for that. It will open Define Icon for Tool \ Import Selected Icon and then search for your file with the Browser button.
Please mark verified answer if this helps you resolve your issue.
José
