Dear Microstation Team,
We imported following other softwares drawing into Microstation and save as to *Dgn V7 version.
Cadworx 2016 Piping model : *. dwg
Cadworx 2016 Steel : ACIS *.Sat
Cadworx 2016 Equipment : ACIS *.Sat
Tekla 21.0 Structures : * .dwg
Further we are getting *.dgn file but its showing wireframe as shown in attached.
We want it to be shaded dispaly.
How we can get 3D solid shaded display dgn file ?
Note : We are using: Software : Microstation 08.11.09.829 trail version , MS-Office 2010 - 64 Bit. Hardware : Workstation Dell Precision T3600
Waiting for reply.
Swapnil M Gholap said:How we can get 3D solid shaded display dgn file?
MicroStation help was installed at the same time you installed MicroStation.
Hi Swapnil,
You screen shot looks like Bentley View CONNECT Edition.
Did you try to open the view attributes dialog box by typing in the search box: view attributes and selecting a Display Styles with shadows?
I believe Display Styles with shadows should be applied to your dgn at least for the current session (dgn file read only)
If you are using Bentley View SS4 use View menu\View attributes to select the Display Style
If this does not work for you please send us the file for testing.
Maria
