As the title, my cursor's crosshair has changed to a blck colour making it impossible to see.
I have tried using key in: set xor to change the colour but it does nothing.
Any ideas?
AC
Hi, did we find a resolution to this? A few of my colleagues are having this same issue. It seems to only happen when you select the element and go to manipulate it.
None up till now, I am having a couple tests run, and waiting to hear back - but yes, seems very strange and hopefully those that are encountering this will be able to replicate any solution that is presented.
Hello, I am having the same issue. It occurs when trying to manipulate the object, it becomes really annoying to try to find the snapping points in darkness. All is black!
I´m very interested if someone finds a solutuion to this, except from the workaround of changeing background colour on the screen to something else than black.
Did anyone find a solution to this? Like Bill Robinson, this is only an issue for me when Microstation projects to a monitor. Unfortunately, I project from a laptop with a small screen not practical for drafting.
