I have created two pattern where symbologies of this two pattern are named as "A and B" such as an example. now I want to change pattern symbology of A to B.
First, I selected match pattern feature from the menu and then click pattern B with activation "match symbology box". Then I activated "change pattern " with all options is selected and clicked pattern A. But no changes is occured. How can I match two different pattern symbology into one symboogy using match pattern feature ?
Best Regards
Özgür
:) ok. You can finde enlosed dgn file.
pattern.dgn
