How to select a coordinate system from a DGN file in raster manager for .ecw image. The option available is to select it from library but the coordinate system is not on the library list and I can not edit the library list without Bentley Maps. Please assist.
If you have accurate survey in a datum you can use then you can ref attach that to a dgn with same datum set then raster manager attach the ecw just by interactive, 2 diagonal points then warp the raster in raster manager by points the more points you can find around the outer edges to match the cadaster or survey the better accuracy the warping will become once you have enough points detach the cadastre or survey and rename your dgn as XYZ Datum Photography Area name.dgn
This depends on scaling as how accurate you can get this as you have to eyeball manual snapping to a pixel in the ecw to get the warping to align with cad real snaps...
You can now use this Dgn as your airphoto file and it will geo ref to any known listed datum...and use the ref manager to attach it reprojected, or world coincedent if same datum...
I dont know if you can export the warped ecw to say Jpeg with a sister file but worth a shot..
there is another method which you creates monument points against known coordinate points ie you know the coordiantes of a round about or a series of pits and these are visible in the raster and you know where they are in the coordinate world and cad file and also in the photo by eye... this is much more complicated method but yeilds better results for accuracy...and I think it remembers the datum you set it too and can be set to the ecw... ( not sure about that, its more for making new un registered datum equivalents).. but I know the first method works very well for areas that are not too big, lots of points and good easy to locate cadastre or survey...
Lorys
Unknown said: I dont know if you can export the warped ecw to say Jpeg with a sister file but worth a shot..
In Raster Manager you can export to a Jpeg with a world file.
The exported jpeg file will have an accompanying jpw world file.
Rod WingSenior Systems Analyst
Unknown said: Lorys I dont know if you can export the warped ecw to say Jpeg with a sister file but worth a shot.. In Raster Manager you can export to a Jpeg with a world file. In Raster Manager select the image to save Select File > Save As from the top menu bar. Set the output type to JPEG Select the Options button In the Raster Save As Settings dialog expand the Geographic Information panel Set the Sister File option to World File The exported jpeg file will have an accompanying jpw world file.
And this works even after we have warped raster that was first placed by interactive just anywhere no datum, then matched warped to a a series of points...
I have tried to export this kind of file but if it works then msnt is even smarted than we thought....!
